Re: Antifreeze leak.
Posted by Bruce (VA) on March 11, 2014 at 17:29:37 [URL] [DELETE] :
In Reply to: Re: Antifreeze leak. posted by Steve9n on March 11, 2014 at 14:33:54:
If you have a leaky water pump, get it fixed.
Because the next thing to fix will be your radiator when the fan comes off the pump! (check out the picture)
Don't replace the pump. Get it rebuilt. If you don't have a shop nearby, try these guys:
Automotive Manufacturers Inc
2400 N Lombardy St Richmond, VA 23220
(804) 321-6861
They do mail order work. And they also rebuild clutches, pressure plates, carbs, alternators, generators, starters & reline brakes.
Posting not permitted in the forum archives.<1394576977">
