In Reply to: Re: low oil pressure posted by TheOldHokie on February 16, 2014 at 09:18:29:
The 10 psi was at idle. Oil pressure all last summer was about 35 psi when fully warmed up and running at about 2/3 throttle (don't have a working tachometer). The
engine was completely overhauled about 4 years ago and the tractor isn't used much. I change the oil often and use 30 weight Castrol.
I was told there is an oil pressure relief somewhere on the front of the block and it might be clogged. Possible? Where is it located?
Many thanks
JWE
Posting not permitted in the forum archives.<1392561335">
