Re: Distributor or Governor
Posted by charles in louisiana on January 31, 2014 at 17:51:11 [URL] [DELETE] :
In Reply to: Distributor or Governor posted by Frank in VT on January 30, 2014 at 20:37:32:
this maybe just starving out.. i would try enriching the idle mixture before i tried anything else. turn the idle mixture in. clockwise a quarter turn. see if it improves it. also run it at a pretty good load and tweek the high rpm needle for best power. this may cure your problem right off the bat.. been there ----done that. check timing as per bruce(va) instructions too.
Posting not permitted in the forum archives.<1391208671">
