Re: Governor Leaking Around Throttle Arms
Posted by TimW(PA) on January 25, 2014 at 10:29:39 [URL] [DELETE] :
In Reply to: Governor Leaking Around Throttle Arms posted by John (AL) on January 24, 2014 at 14:41:51:
"Additionally, the throttle arms are wobbly - they wobble perpendicular to the rod they sit on....."
"3) can the throttle arms be tightened without disassembling the governor?"
John, I had the same problem on mine. Del Huebner's pic shows he bushing that is pressed onto the aluminum housing. When I did mine several people insisted that the bushing didn't exist, but after talking to Don at Just8N's we confirmed it was original. Anyway the fix is to have the arms bored out at a machinist and have them make and press on a new custom bushing to match. you can't just do the bushing because the oblique pressure that occurs on the arms causes the hole in the arms to be both conical and egg shaped/ Hope that helps
Posting not permitted in the forum archives.<1390663779">
