I have a two sided question......first, I have a late side distributor 8N. Right from the time I got it I have noticed that it was harder to steer left than right. I searched the archives and found some information that this is due to a problem internally in the steering box. I added a second grease fitting and have filled both with grease but I do not notice much, if any, improvement in the steering. I suspect that new steering box is in my future? The tractor still runs fine and I can go left but it just requires more grunt! Secondly, I have noted that the front tires seem to be toeing out more than I would like. The steering parts in the front end seem tight and most have been replaced. Question......can the toe out problem be related to the turning left problem?? Can this be caused by a worn steering box? Actually I should also mention that the toe out looks greater at some times than others.......love my tractor. Dave
Posting not permitted in the forum archives.<1387121163">
