Re: Governor Fork Pin in Shaft
Posted by Jon Bennett on October 31, 2013 at 07:46:57 [URL] [DELETE] :
In Reply to: Governor Fork Pin in Shaft posted by Acadianbob on October 30, 2013 at 23:14:24:
I recently went through the same experience. I just used a punch from the oil plug side and went at it. It should not require a bunch of force. The pin in mine appeared to be a roll pin with a chamfered end. On mine it did not appear to make any difference which side it was inserted or from. I did it through the oil hole because it seemed easier to get to with the punch.
Posting not permitted in the forum archives.<1383220017">
