Re: 3 point lift question
Posted by ZANE on October 09, 2013 at 21:32:00 [URL] [DELETE] :
In Reply to: 3 point lift question posted by Kevin on October 08, 2013 at 12:46:22:
Since you've been an auto Tech for 35 years maybe you could give me a clue as to why my 1985 Toyota truck with EFI won't run???
I have replace the fuel pump, Fuel filter, Fuel injectors, Computer, distributor, mass air flow, ignition coil and igniter and peeled back most of the under hood wires to look for corrosion, None. Double checked all the fuses several times.
I finally just gave up about a month ago till I can get some ideas I haven't tried.
Also Ohmed out the throttle position sensor.
Zane
Posting not permitted in the forum archives.<1381368720">
