In Reply to: Re: what is it posted by Dean on October 02, 2013 at 16:29:27:
There was a bit in the 9n newsletter about the pump center was made by Vickers.The vane pump dosent work well with 134 fluid in hot weather.A change to 90 gear oil as specified in the Ford service manaual fixed my weak pump.Cost 15 bucks to fix with the right oil.I sawed wood for 3 hours yesterday and had no trouble lifting the saw at idle speeds when I moved from piles of 4 foot wood.Try 80/90 weight oil in the hydraulic system be fore you go ape a spend a lot of money.
Posting not permitted in the forum archives.<1380799917">
