Re: what am I hearing?
Posted by RockyMO on July 21, 2013 at 00:54:50 [URL] [DELETE] :
In Reply to: what am I hearing? posted by 2nTony on July 20, 2013 at 22:32:43:
Thruuuum, hmmmm, does it change with the clutch? I suspect a bearing, just which one. Input shaft bearing would be a constant, throw out or clutch release bearing would change clutch pressed or not. Does the tractor have to be moving or will it do it sitting still? In gear? In neutral??? I can't hear the noise so will try to assist in pinpointing the location.
Rocky in MO
Posting not permitted in the forum archives.<1374382490">
