In Reply to: 9N 1000C Generator posted by Steve Dabrowski on July 19, 2013 at 15:37:27:
Steve-
In addition to what JMOR said, you can tell the difference between a 9N-10000-C generator and a 2N-10000 generator by the presence or absence of the two 1/4-28 tapped holes on the barrel. If you have the two tapped holes, then you have a 2N unit, if the two holes are missing, you have a 9N-C unit. The two generators are virtually the same other than that. Both have the large barrel as compared to the earlier 9N-10000-A and 9N-10000-B generators. Both 9N-C and the 2N have a one-wire connection, three brushes, with the third brush adjustment made via a potentiometer with a screwdriver slot on the back end plate. The 9N-10000-C generator will accept the tensioning bracket kit that includes a full band which encircles the entire barrel. I am unsure if the tensioning bracket kit will also fit the earlier 9N-A and 9N-B generators as they had smaller diameter barrels. So, to verify what JMOR said, your 9N-10000-C generator would have only had the single mounting bolt from the factory, however, the tensioning kit could have been added after '45 when it was released as dealer optional equipment. With all the problems Ford had with the 9N charging system design, I'm surprised that it took them 6 years to come up with s solution to the belt tensioning issue. Ford was usually on top of fixing problems as soon as they appeared, often on the fly and not always being documented. As my late uncles told me, they would have to be sure to stop their 9N tractor every few hours and retighten the generator bolt to ensure the battery didn't get drained from a loose fan belt, and they'd be left stranded at the end of the day. The 2N-10000 generator had the tensioning bracket installed via the two 1/4-28 tapped holes on barrel -see my reply to Corey below...
9N-10000-C Generator with Tensioning Bracket Kit Installed-
Posting not permitted in the forum archives.<1374324972">
