Re: Fuel problem
Posted by R Geiger on July 18, 2013 at 12:31:13 [URL] [DELETE] :
In Reply to: Fuel problem posted by tex prexhurst on July 18, 2013 at 10:56:38:
With the float in the closed position it should be 1/4" from the gasket surface. With the carb removed from engine and taken apart turn body upside down and let the weight of the float close the needle and then measure for 1/4" from the nearest face of the float to the gasket surface.
Posting not permitted in the forum archives.<1374165073">
