In Reply to: 8N Steering posted by Jerry Vincent on July 15, 2013 at 22:45:56:
if the double sector starts turning WAY befor ethe single sector.. you have too much sector backlash. on the early box you rotate the round cover to snug it.. if you hav eno adjustment left.. may be time for bushings.. OR if not.. check the sector gears.. are the teeth excessively worn? I have a 2000 that had teeth almost pointed. :)
Posting not permitted in the forum archives.<1374151807">
