In Reply to: Re: Clutch Issues...... posted by soundguy on June 03, 2013 at 11:34:41:
Wow! Thanks a ton.
Well,
Clutch won't disengage. Grinds when I go to put it in gear. I will go block it and check back with ya. It does have a leak from below the PTO shaft that is healthy sized. Leaves a small pool when left for a few days. Don't know of any from bellhousing. Will check that out while out blocking..... Thanks a ton....off to follow directions. Will be back. Where is the weep drain?
Posting not permitted in the forum archives.<1370289240">
