Re: n 9 running rough
Posted by dave manning on June 02, 2013 at 13:30:40 [URL] [DELETE] :
In Reply to: Re: n 9 running rough posted by TimW(PA) on June 02, 2013 at 12:17:12:
Thanks for the help, I believe I got firing order correct and the point gap. I will pull the distridutor and check the timing .I will let you guys know if I have any luck.If this does not do it could it be an internal enine problem ? Valve stuck ???
Posting not permitted in the forum archives.<1370194240">
