Re: Using the Dearborn Tractor Jack
Posted by Tim Daley(MI) on May 23, 2013 at 06:42:37 [URL] [DELETE] :
In Reply to: Re: Using the Dearborn Tractor Jack posted by Kirk-NJ on May 23, 2013 at 05:52:48:
The weight doesn't shift. I change my good show tires with my loaded work tires often, on and off all summer as I take my 8N to tractor shows and work it in between. The lift keeps it stable. Now, if you use a floor jack, yes the weight will shift
Tim
Posting not permitted in the forum archives.<1369305757">
