Re: 9N runs bad
Posted by charlie in bedico on April 29, 2013 at 17:16:10 [URL] [DELETE] :
In Reply to: 9N runs bad posted by Mark on April 28, 2013 at 12:17:30:
Mark,
Sounds like a bad vacuum leak.
Intake manifold gasket/ Carburetor mounting gasket/ Throttle shaft bushings.
Check with brake or carb cleaner spray around intake to head sealing surface/
carburetor mounting gasket. when you find the leak the engine will even out
for a few seconds.
Hope this helps.
Charlie
Posting not permitted in the forum archives.<1367270170">
