Re: Removing crankshaft pulley - 1952 8N
Posted by Dantforth on April 21, 2013 at 04:54:03 [URL] [DELETE] :
In Reply to: Re: Removing crankshaft pulley - 1952 8N posted by K.LaRue-VA on April 20, 2013 at 23:02:39:
I already have the radiator and hood removed after draining coolant and fuel. I actually started this because there was no fan shroud on the radiator so I ordered a replacement. So, I am struggling trying to get that to fit. I also discovered that my radiator is marked "2N" on the top tank and also the bottom hose connection. While in there I decided to change the very wobbly cranhshaft pulley. So, I have the front supported by my floor jack and have the six bolts removed from the axle support bracket which attaches the axle to the front of the engine. It looks like I can continue to raise the jack and the front of the tractor should just pull up and away from the axle assembly, exposing the pulley? Will this manouver break anything? It looks like the radius rods and drag links will just swivel enough to allow this. This method would allow me to avoid having to wrestle with the whole front axle assembly. Thoughts??
Posting not permitted in the forum archives.<1366534443">
