In Reply to: Stabilizer link bars posted by ScottNC on April 16, 2013 at 10:32:14:
You should only need adjustable length stabilizer arms if you intend to use the same bars on tractors that require different lengths. If that's the case, I'd mark the correct position for each tractor right on the bars. If the pins are not located correctly, as has been covered by others, fix that first.
Even when the stabilizers are the correct length, I've never been able to connect them with the implement on the ground. I used to just let the stabilizers drag on the ground, raise the implement, pull forward a bit to get the implement out of the weeds and ticks, and then hook up the stabilizers. That worked OK until I forgot and tried to reverse. That brain fade will turn the loose stabilizers into spaghetti every single time. It was a simple task to make a couple of hangers so the loose stabilizers can hang on the side of the lower arms until I get where I can hook them up.
Posting not permitted in the forum archives.<1366226702">
