Re: Stabilizer link bars
Posted by Rick H. on April 16, 2013 at 13:09:01 [URL] [DELETE] :
In Reply to: Stabilizer link bars posted by ScottNC on April 16, 2013 at 10:32:14:
Scott,
Are the implements you're using all standard Cat 1 configuration? I think some of the implements out there for sub-compact/Cat 0 tractors have the bottom attachment pins closer together. I have a 48" box blade that was previously used with a sub-compact JD tractor and the bottom attachment pins are closer together than all my other implements. Thus only one stabilizer bar will hook up, and that is with the blade pushed to one side. If you think about the geometry it makes sense. The lift arm is the 'fixed' side of the triangle so stabilizer bars would need to be longer for them both to connect as that side of the triangle is now longer. The dimensions in the second picture are approximate but you get the idea.
Rick
Posting not permitted in the forum archives.<1366132141">
