In Reply to: Stabilizer link bars posted by ScottNC on April 16, 2013 at 10:32:14:
You likely have either non-original stabilizer bars, lower lift arms or both. Not good for a match up. Best option would be to find some good steel stock and by centering the attached implement carefully measure and cut the bars to fit. Or, if your existing bars are still useable straighten and cut and weld holes to suit. Problem is that the standards for hitch categories did not exist until after 1970 so you sure can find a lot of mis-matches with earlier equipment. Adn,no the Ford Tractors of the 30's, 40's 50's and 60's are not "category 1", just close.
Posting not permitted in the forum archives.<1366128634">
