Re: Stabilizer link bars
Posted by Larry (TX) on April 16, 2013 at 11:14:24 [URL] [DELETE] :
In Reply to: Stabilizer link bars posted by ScottNC on April 16, 2013 at 10:32:14:
Though I don't know which brand or model your tractor is, if your stabilizer brackets are original (which would present no problem whatsoever if mounted correctly) or aftermarket models, I can tell you that with the aftermarket models with the multiple holes, the pins have to be mounted in the holes that directly line up across from the lift arm pins in the axle trumpets, otherwise, bending of the stabilizer arms will occur.
Having had a side tractor business using Ferguson, Ford and Massey-Ferguson tractors for more than forty years, I have yet had to loosen a fender to install a stabilizer bar, nor have I ever bent one.
Posting not permitted in the forum archives.<1366125264">
