In Reply to: Re: 8N with 6 cylinder 288 cu. in. motor posted by Mike Suflita on March 19, 2013 at 16:16:36:
Don't know the HP on the 6 cylinder but it is not a factory set-up. There are a few different company's that made a conversion,the most common is Funk.They also made a conversion for the Ford flathead V8.The problem if you work the tractor is that the extra HP is hard on the tranny and rearend.Also they are a lot higher RPM engine. JMHO
carl ny
Posting not permitted in the forum archives.<1363729140">
