Re: Sherman reverser transmission
Posted by Kirk-NJ on April 06, 2026 at 06:12:36 [URL] [DELETE] :
In Reply to: Sherman reverser transmission posted by Edward on April 05, 2026 at 19:23:40:
As Ed said make sure you get the correct one cause most will be fine spline input shaft. You need one out of a 600/800. It might be possible to swap out the input shaft and nose cone from the fine spline to a course spline by using one off a combo but I haven’t done one off a reverser so you would have to check part numbers to see if it would work. You will have to relocate the hole cause it’s not in the same position as the step up. Reverser is worth three times as much as a step up so best to sell it once you find reverser.
