Re: Governor and Carbuator linkage
Posted by Paul (IN) on February 21, 2026 at 17:39:44 [URL] [DELETE] :
In Reply to: Governor and Carbuator linkage posted by Pete Landon on February 21, 2026 at 17:24:28:
On a 2n I used to have, the small pin that holds the lever on the bottom of the shaft below the quadrant was worn internally and created quite a bit of free play.
You can't tell by looking at it, grab the small lever in one hand and work the throttle lever with the other and look for slop there.
A new roll pin made a pretty big difference.
