In Reply to: Ford 8N / Deland, FL - looking for guidance - please posted by Gerald Lane on February 17, 2026 at 06:04:36:
You didn't mention ignition wires which could be breaking down. In addition, I would make sure the fuel filter screens are clear.There's a couple I believe.Also, make sure you are using Champion H-12 plugs gapped at .025. Finally, check and make sure the distributor is not worn. If there is excessive sideway slop of the distrubutor, you will never get a uniform point gap for each of the four lobes.
