Re: Fuel bowl and filter
Posted by John in Mich on December 20, 2025 at 20:34:31 [URL] [DELETE] :
In Reply to: Fuel bowl and filter posted by Island Mike on December 20, 2025 at 15:51:12:
I have replaced numerous fuel valve/sediment bowl assemblies over many years. The less fuel in the tank when you start is better. Know for sure how much is in the tank before you start. Turn the valve clockwise to close it. Disconnect the fuel line at the carburetor and aim it into a funnel and gas can. If you have more than the container you are draining into you have to pay close attention to it. If the container is getting full, shut off the valve and empty it or switch containers.
Normal operation with a good valve is open two 2 turns to normal operating position for about 9 gallons of gasoline while working. Wide open allows the 10th gallon (reserve) to be used to get back from a field to your fuel source.
Opening it all the way does NOT necessarily mean that the tank is empty. If the reserve port of the valve is plugged, you could have a sudden flood of a gallon of gasoline when you remove the assembly. Do NOT assume that all the gasoline has been drained.
So, hold a container under the valve as you unscrew it. Catch the valve and any residual gasoline. DO NOT HAVE ANY OPEN FLAMES IN THE AREA!
New valves that I have purchased have two possible ports to connect the fuel line. One will have a plug in it. Determine which port that you will use and the plug should go into the other one. I use Teflon tape on the new valve threads. Install it and orient the port in the direction of your fuel line to the carburetor.
If you don't have an original steel line, GET ONE! Copper and rubber are NOT acceptable. New, pre-formed lines are readily available.
Put no more than 2 gallons of fuel into the tank to check for leaks and proper valve function. Do NOT yet open the valve. Remember, that there is enough fuel in the carb to start the tractor. Start the tractor and let it run until it starves for fuel and stalls, THEN open the valve 2 turns. Watch the sediment bowl for fuel flow. When it stops, the carb bowl should be full. Start the tractor again. Runs? Good so far.
Turn the valve off again, disconnect the fuel line at the carb and again aim it into a safe container.
When is stops flowing, open the valve all the way. The last gallon should now drain into your container.
When fuel flow stops, shut off the valve and reconnect the fuel line to the carb. Put gasoline into the tank and open the valve 2 full turns.
Again, examine all joints for leaks.
Easy, peasy. Good luck.
