Re: Seeking help to rebuild 9N distributor
Posted by Bruce Dorsi on October 28, 2025 at 10:51:44 [URL] [DELETE] :
In Reply to: Re: Seeking help to rebuild 9N distributor posted by HM Skeezix on October 28, 2025 at 08:49:31:
Remove the hose/tube at the inlet of the carb.
...Hold your hand against the carb inlet while cranking the engine.
...Do you feel a strong suction?
After hand choking, are the spark plugs wet with fuel?
...If not, there may be a vacuum leak in the intake?
Water in the gas? ...Fresh gas, not old gas that has lost most of its volatility?
The low compression in one cylinder should not prevent the engine from starting.
