Re: 2N with starters and magnetos
Posted by Tom (WI) on August 21, 2025 at 20:24:03 [URL] [DELETE] :
In Reply to: Re: 2N with starters and magnetos posted by Ed Gooding (VA) on August 21, 2025 at 11:09:35:
Thanks Ed. I have looked at this information on the 2N. Yes, very informative. Mine had all the electrics when I got it and the more I looked at it the more I found it as to be an original 2N Warhorse. The hole in the dogleg for the choke rod. The different front axle. The double throw choke shaft on the carb. The serial number, 111677 makes it a 43 Warhorse. When it was made, it was a Warhorse. Someone put electric, rubber tires, starter. Now I am putting it back to original, hopefully. I have everything I need to do it, mag, angle drive, steel wheels, took me forever to find these things. Now, my next step is to fire it up. I just saw these 2Ns with the starters at the show still on and wondered if it can be started with the mag. on and not damage anything. I really didn't want to hand crank it for the first time starting as it has been sitting for a little while. Thanks to all....
