Re: Clutch Knocking Noise
Posted by Roger ID on April 10, 2025 at 19:48:05 [URL] [DELETE] :
In Reply to: Re: Clutch Knocking Noise posted by Travis Webb on April 09, 2025 at 21:24:49:
Not a huge job unless you have a loader. If you have a loader it would need to come off first.
I did my 2240 John Deere. It was a big job. Had to drop my loader. Then there was steel hydraulic lines from the pump on the front of the engine to separate.
Good Luck.
Plan on good blocking for the engine end and a good transmission Jack for the transmission so you can roll it apart.
