Re: Pie weights
Posted by Dean on April 07, 2025 at 10:20:55 [URL] [DELETE] :
In Reply to: Pie weights posted by Jim on April 06, 2025 at 15:06:58:
Fitment will depend upon two primary factors; wheel lug bolt pattern and rim size.
If your tractor has 8 wheel lugs with the same pattern as vintage Ford tractors the mounting disc will most likely mount.
If your tractor has 24" rims/tires, as is likely, you will need to find pie weights designed for 24" rims, which are much less common. That said, it may be possible to mount the much more common pie weights designed for 28" rims on 24" rims if the wheels are set fully inward.
