In Reply to: Early 39 9N transmission numbers posted by Damon Bunting on March 25, 2025 at 02:33:49:
That’s an early stamping. Was there an LR also stamped somewhere on the flange? There was no rhyme or reason on the order they were used. Case in point, Joel and Paul Wilber have #90 with 183 Trans and #91 with 186 trans. I have #388 with 187 trans. It was typical for the trans numbers to be within a few hundred numbers of the engine numbers. That being said I would say it’s of an aluminum hood tractor. If you want to send me some photos of the tractor from all sides I can tell you some early things to look for. Kirk9N546@gmail.com
