In Reply to: 8N crankshaft pulley removal help posted by Travis Webb on March 16, 2025 at 15:34:52:
You should be good to go once you get the bolt out. Careful prying to hard on the pulley, may bend the sides in and then your belt won't run true and stay in the groove. Tap ever so gently around the pulley with a small hammer to see if that won't help it work loose.
