In Reply to: Re: 8n differential posted by KCM on December 31, 2024 at 19:34:53:
I do not know but thinking about it here...
My guess is no.
On the inside of the left trumpet there is a rubbing block to prevent excess sideways thrust of the differential when under heavy load.
Is the right trumpet cast to add that rubbing block?
We know the trumpets can't be swapped from left to right.
On the 7xx and 9xx row crop tractors the differential ran backwards from the 6xx and 8xx tractors because of the drop down boxes on the outer ends of the axles.
But I believe the architecture of the entire center housing and trumpets are designed to run backwards.
