Re: Governor idle adjustment And timing advance
Posted by Ed Gooding (VA) on December 09, 2024 at 09:10:40 [URL] [DELETE] :
In Reply to: Governor idle adjustment And timing advance posted by Tim on December 08, 2024 at 21:51:54:
Do you have the owner's manual? There are instructions in there on how to make adjustments to the governor control rods to affect the idle.
The top advance is 18° per factory specs so it sounds like you are there. I doubt you will get enough additional power to justify messing with it.
