Its been a while since I've posted here. '51 8n side mount.
I am looking into lowering my idle speed. If I remove the rod from the governor to the carb I can get my idle down to 400. But when I hook it back up its at 900. Is there an adjustment somewhere that I'm missing?
Also, does anyone know the max timing i should see at 2200? I'm getting around 19 degrees. Have anyone increased it any to get a bit more power?
Thank you,
Tim
