In Reply to: Tractor not starting posted by Larry meyers on November 17, 2024 at 15:38:33:
there is corrosion under the crimped lug on the battery cable that you cant see unless you cut it off. corroded /dirty/loose connections cause heat. some auto/battery stores can repair or provide a new copper lug and a loan a tool to crimp it back on.
