In Reply to: Tractor not starting posted by Larry meyers on November 17, 2024 at 15:38:33:
Are you saying the starter won't crank the engine or the engine fails to start with good cranking ability of the starter?
It's sounds to me from your description your starter has issues and is pulling a lot of current. I would atleast start by cleaning all battery, engine ground and starter connections.I would have the battery tested just to rule that out before proceeding to the starter.
