Re: Differential bolt torque
Posted by Farmer Brown on July 26, 2024 at 05:16:41 [URL] [DELETE] :
In Reply to: Differential bolt torque posted by Steve Dabrowski on July 24, 2024 at 14:23:39:
Torque specs are based on the load and application, not the grade of bolt used. Bolt grades each have torque limits and vary according to size, those torque limits have nothing to do with their actual application.
Just because you use a higher grade bolt than the original for the same application doesn't mean you torque that bolt higher.
