Re: 1952 8N Governor preventing slow idle
Posted by Jim Menke on June 07, 2024 at 09:51:49 [URL] [DELETE] :
In Reply to: Re: 1952 8N Governor preventing slow idle posted by Bruce(OR) on June 05, 2024 at 11:11:12:
I solved the problem. It was not the governor. The bolt that holds the lever assembly to the lever rod, was stripped and allowing it to move. Replaced the bolt and it idels as low as I want it to. Thanks for the input. Was a bit surprised that no one else commented, but all is good!
