Re: 8N Oil Pressure
Posted by Travis Webb on May 29, 2024 at 19:30:06 [URL] [DELETE] :
In Reply to: Re: 8N Oil Pressure posted by Farmer Brown on May 28, 2024 at 23:28:11:
Thanks Farmer Brown; I did forget to purge the air out. I disconnected the line and did that, and then re-connected. The needle still bounces, but not as bad; I can live with it for now.
I'm still getting around 20 PSI on startup, and warm, and when full throttle about 25 PSI. Next time I change the oil, maybe I'll give it some heavier weight oil. Is 20 ok to run it for now? How low is too low?
