Re: Generator causing a miss
Posted by Jeff on September 28, 2023 at 19:23:23 [URL] [DELETE] :
In Reply to: Re: Generator causing a miss posted by Ed Gooding (VA) on September 28, 2023 at 18:33:04:
Yes, 12 volt battery is fully charged. Yes, 12 volt coil. No I don't have a resister in the wire going to the coil. If you have a low resistance coil you don't need a resister, do you?.
