Re: 4 speed transmission locked up
Posted by Bruce(OR) on August 31, 2023 at 14:28:09 [URL] [DELETE] :
In Reply to: 4 speed transmission locked up posted by Beargap on August 31, 2023 at 02:40:38:
Get yourself a block or two of wood, and a jack. Block the wheels, jack it up, move the rear wheels a bit back and forth and take the strain off the transmission. Now shift to Neutral and get it back to the barn. Yes. You can drive it. Shift it goofy again and you can repeat the jacking and moving routine.
Take off the trans cover and look at the worn out linkage that needs repair/replace and the shift detent balls that might be also rusted/varnish glued into position.
Others with more smarts will be along shortly.
