Re: 2N...noisy transmission
Posted by Ed Gooding (VA) on August 24, 2023 at 11:11:07 [URL] [DELETE] :
In Reply to: Re: 2N...noisy transmission posted by Kevin Fisher on August 24, 2023 at 08:23:59:
So, it sounds like you have either the step-up or step-down Sherman and not the combo (high/low) that has the dogleg shifter. Did you use Kirk's method to determine which one you have? The step-down is highly desirable and can add a little value to your 2N.
