Ford 8N Fuel Issues
Posted by Craig DuMond on August 21, 2023 at 16:56:33 [URL] [DELETE] :
while recently running my 8N it started acting up like it was running out of fuel. It was low so I added more fuel and it ran fine as usual. The next day it started acting the same way, shortly after start up acting like it was running out of fuel.
When it first starts acting up, if I slow the throttle speed it will straighten up for a minute or 2 and then starts spitting and sputtering again until it eventually dies.
I have checked the screens and even completely replaced the sediment bowl assembly but the problem is still there. It appears to be getting fuel as when I loosen the sediment bowl assembly or screw on the bottom of the carb I get gas.
Any suggestions?
