Re: 2N...noisy transmission
Posted by John in Mich on August 17, 2023 at 20:36:11 [URL] [DELETE] :
In Reply to: 2N...noisy transmission posted by Kevin Fisher on August 17, 2023 at 16:09:05:
Over the years the shift lever can wear the socket of the transmission cover. That allows the shift lever to drop down and to be rubbed by the gear. Lift the rubber cover and look at the wear. You can try lifting up on the shift lever while the tractor is running and see if the noise stops.
