Front engine cover
Posted by Steve Dabrowski on July 29, 2023 at 15:00:36 [URL] [DELETE] :
Need a front engine cover in good condition for my 9N, especially the front camshaft bearing surface that limits the axial movement of the camshaft. My cam is original with press on gear so does not use the spring piece used with later cams with bolt on gears.
Anyone with a good AL or steel cover from a 9N, 2N or 8N will do-all are the same part number.
