In Reply to: 1950 8N carburetor and timing issues posted by Andrew on July 04, 2023 at 23:36:38:
There is a neat tutorial in our How-To's/Fuel System library that shows a way to measure the level in your fuel bowl while the tractor is running. That may help here.
Also, are you holding the choke out when you start it? It is often not needed - turn the engine over first and then do a quick pull and release on the choke knob.
