Re: FEL Pump
Posted by TheOldHoke on July 03, 2023 at 09:44:13 [URL] [DELETE] :
In Reply to: Re: FEL Pump posted by Charles Hudson on July 02, 2023 at 06:49:53:
The mounting foot is stabdard SAE-A two bolt flange and will fit any SAE-A 2 bolt pump.
The lower flow rating is a better match to the reservoir capacity of the loader. A higher flow rate will decrease the time it tskes for loader to go from full down to full up. Meaure bore andcstroke on the lift cykinders andcwe can calculate thos numbers.
TOH
