In Reply to: Re: Headlight Switch posted by J52J on May 13, 2023 at 07:20:25:
Even on your Jubilee, you should have a terminal block mounted on the engine side of the dash. Your alternator, coil, and ignition switch should be connected to it. Do you have one installed? If so, connect the hot wire from your headlight switch to the opposite connector to the one where your ignition switch is wired.
