In Reply to: Gripman posted by Rick on April 27, 2023 at 11:50:29:
The plug has an extension that goes through the case, reverse idler support and reverse idler shaft to hold the shaft in place. Take you a small screwdriver, stiff wire etc. to try to find and align the holes. Be gentle try not to move the shaft forward, backward or rotate very much. Transmission in neutral or gear when you removed it.
